[GRASS-user] v.db.connect error (Grass 6.4.0RC4 on OSX 10.5.8)
Richard Chirgwin
rchirgwin at ozemail.com.au
Mon Dec 14 20:19:53 EST 2009
Glynn,
Thanks ...
(Chastened)
Cheers
RC
Glynn Clements wrote:
> Richard Chirgwin wrote:
>> There is a slip in the command-line parsing of v.db.connect.
>> The GUI works ok, but the same command, pasted to the command line,
>> produces this:
>> > v.db.connect -o map=CD_act driver=dbf
>> database=$GISDBE/$LOCATION_NAME/$MAPSET/dbf table=cd_act_2 key=cat layer=1
>> > ERROR: Table <cd_act_2> does not exist in database <///dbf>
>> Note the extra slash characters added by v.db.connect here...
> This isn't a problem with db.connect, but with the way that you ran it
> from the shell.
> You need to quote the database= option (with single quotes), otherwise
> the shell will interpret $GISDBASE, $LOCATION_NAME, and $MAPSET as
> variable substitutions. As these variables aren't defined, they are
> replaced by the empty string, giving the result you see.
> IOW:
> v.db.connect -o map=CD_act driver=dbf 'database=$GISDBASE/$LOCATION_NAME/$MAPSET/dbf' table=cd_act_2 key=cat layer=1
> If you run v.db.connect from the GUI, the shell doesn't get involved,
> so this isn't an issue.
> bash (which I assume that you're using) has quite thorough
> documentation (around 80 pages) available via "man bash" or at:
> http://www.gnu.org/software/bash/manual/
> While much of that information is only necessary for scripting, it is
> important to learn which constructs the shell interprets, and how to
> prevent it from doing so.
