[GRASS-user] g.region (was v.to.rast conversion)
Giacomo Piva
piva at meeo.it
Tue Dec 15 02:46:44 EST 2009
Giacomo Piva wrote:
> Hamish wrote:
>> Giacomo Piva:
>>> First of all, thanks for your reply.
>>> To clarify my problem, i want to specify that the main
>>> problem is that all command that involves the g.region always
>>> returns the
>>> reported error (ERROR: default region is not set.) also the "help".
>>> I found a similar discussion here:
>>> http://lists.osgeo.org/pipermail/grass-user/2009-November/052988.html
>>> Where the solution was to use of the SVN version of the
>>> grass.
>>> I already tried to use that version, bunt nothing changed.
>>> Any me any suggestions?
>> maybe the rc5 bug is now gone, but the corrupted WIND file still
>> remains in your mapset. try 'g.region -d' to reset it.
>> does it work from a newly created mapset?
>> Hamish
> Hi Hamish,
> Maybe it could be usefull to do a backward step.
> I should convert a shapefile into a raster file (GeoTIFF format) at a
> given resolution and I want to use the GRASS modules as a command line
> tools.
> I followed the instructions in the chapter "Automated usage of grass"
> in the Markus's book and I created a bash script in order to prepare
> the grass enviroment:
> #!/bin/bash
> LOCATION=test
> GISBASE=/usr/local/grass-6.5.svn
> GISDBASE=/usr/local/share/grassdata
> rm $HOME/.grassrc6
> rm -rf "$GISDBASE/$LOCATION" #cleaning LOCATION
> TMPDIR=$$.tmp
> mkdir -p $GISDBASE/$TMPDIR/temp
> echo "LOCATION_NAME: $TMPDIR" > $HOME/.grassrc6
> echo "MAPSET: temp" >> $HOME/.grassrc6
> echo "DIGITIZER: none" >> $HOME/.grassrc6
> echo "GISDBASE: $GISDBASE" >> $HOME/.grassrc6
> export GISBASE=$GISBASE
> export GISRC=$HOME/.grassrc6
> export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
> After these lines I run the v.in.ogr module to import the vector:
> v.in.ogr -o -e dsn=./test_data/test_data.shp output=grass_map
> And the following is the error i get.
> ERROR: region for current mapset is not set
> run "g.region"
> I tried to get the g.region help message, also I tried to reset the
> region (with g.region -d) and to set a default region (with g.region
> -s) but I get always the same error.
> I'm very new with GRASS and I cannot understand if there is a problem
> in the installation, or it is a bug (as it seemed), or I'm not working
> in the proper way.
> Thanks (also for the patience)
No suggestions?
Giacomo Piva
MEEO S.r.l.
Via Saragat 9
I-44122 Ferrara, Italy
Tel: +39 0532 1861501
Fax: +39 0532 1861637
http://www.meeo.it
"ATTENZIONE:le informazioni contenute in questo messaggio sono
da considerarsi confidenziali ed il loro utilizzo è riservato unicamente
al destinatario sopra indicato. Chi dovesse ricevere questo messaggio
per errore è tenuto ad informare il mittente ed a rimuoverlo
definitivamente da ogni supporto elettronico o cartaceo."
"WARNING:This message contains confidential and/or proprietary
information which may be subject to privilege or immunity and which
is intended for use of its addressee only. Should you receive this
message in error, you are kindly requested to inform the sender and
to definitively remove it from any paper or electronic format."
