[GRASS-user] V.overlay very slow
incanus
andresfr at unizar.es
Tue Dec 15 10:22:58 EST 2009
Thanx again Markus, you always saving me :D
patch followed by v.clean with break,rmdupl and later v.build make it really
fast!
Markus Metz-2 wrote:
> If you just want to create one big vector with all features present in
> several other vectors, try v.patch followed by v.clean.
> For cleaning after patching areas, you will need at least to break
> polygons and remove duplicates. If topology is still not correct, try
> cleaning small angles at nodes followed by breaking lines, then remove
> duplicates. If topology is still not correct, snapping vertices may be
> necessary, here try a very small threshold first. Also see the v.patch
> manual.
> Hope that helps,
> Markus
> incanus wrote:
>> Hi all,
>> I'm trying to join a large set of "vectorial tiles" that i have, into a
>> unique vectorial map. What i'm doing is something like this, for each
>> "tile"
>> (in the example is called filaN):
>> v.overlay ainput=sumaFilas atype=area alayer=1 binput=fila6 btype=area
>> blayer=1 output=sumaFilas2 operator=or olayer=1,0,0
>> v.db.addcol map=sumaFilas2 layer=1 'columns=union INTEGER'
>> v.db.update map=sumaFilas2 layer=1 column=union value=1
>> v.dissolve input=sumaFilas2 output=sumaFilas2 layer=1 column=union
>> --overwrite
>> g.remove vect=sumaFilas
>> g.rename vect=sumaFilas2,sumaFilas
>> At first, the v.overlay is instant, but when processing the map number
>> 100,
>> it can be several hours.
>> Anyone knows an alternate way to do this?
>> The first solution I adopted was making this by rows of 100 "tiles", and
>> then joining the rows (what i'm doing in the example above). It worked
>> for
>> me since i only has todo a "small" map (1 week of processing), but now i
>> need to do one MUCH more big.
>> Thanx in advance if anyone knows something.. or not :)
>> Andres
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/V-overlay-very-slow-tp4169783p4170405.html
Sent from the Grass - Users mailing list archive at Nabble.com.
