[GRASS-user] Re: grass-user Digest, Vol 44, Issue 47
Michael Barton
michael.barton at asu.edu
Tue Dec 15 13:30:00 EST 2009
On Dec 15, 2009, at 11:21 AM, grass-user-request at lists.osgeo.org wrote:
> Date: Tue, 15 Dec 2009 18:20:56 +0000
> From: Gilbert Ferrara <gilbertferrara1974 at gmail.com>
> Subject: [GRASS-user] NVIZ on wxpython 6.4
> To: grass-user at lists.osgeo.org
> Message-ID:
> <bf5eea780912151020i7201b9fcxe030638aa02c3e38 at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Greetings you all
> I'm new at this mailing list and I have a question related with NVIZ
> module.
> I saw in previous messages that NVIZ is available at WinGRASS using
> TclTK.
> But at LINUX it also requires tcltk, right?
> Ok I used the command: nviz elevation vect=roadsmajor
> points=firestations
This should be: nviz elevation=rastermap vect=roadsmajor
points=firestations
elevation is an argument. You need a raster map as in elevation=mymap
Michael
> and I get NVIZ window totally jammed. And when I unselected
> "surface" I got
> this error window:
> Bad window path name ".help_shell"
> bad window path name ".help_shell"
> while executing
> "winfo reqwidth $_top"
> (procedure "DynamicHelp::_show_help" line 22)
> invoked from within
> "DynamicHelp::_show_help .middle.panelarea.panels.main.midt.b2 317
> 323"
> ("after" script)
> Question: Does any one LINUX User, has the same problem? Or knows
> how to fix
> this?
> Thanks
> Gilbert
