[GRASS-user] Compiling GRASS 6.4.0RC5 on AIX 5.3
Glynn Clements
glynn at gclements.plus.com
Tue Dec 15 14:33:45 EST 2009
Mike Waldron wrote:
> The source code tweaks I had to make were mainly to resolve conflicts
> with variable declarations in the math.h include file. These didn't
> cause a problem on Linux, but the xlc compiler on AIX would choke on
> these. Also, there were several include references to <sys/fcntl.h>,
> which on AIX is located in <fcntl.h>, so again a peculiarity with AIX.
FWIW, POSIX specifies <fcntl.h>. Linux has both, but <sys/fcntl.h> is
just:
#include <fcntl.h>
In 7.0, the only two source files which use <sys/fcntl.h> are
r.drain/main.c and r.fill.dir/main.c; all others use <fcntl.h>.
I've fixed this in 7.0 with r40022.
