[GRASS-user] Wxpython vector digitizer
Luis Lisboa
luislisboa1975 at gmail.com
Fri Dec 18 06:18:58 EST 2009
Douhhhhh
Ok when I run SVN I used this command
./configure --enable-64bit --with-libs=/usr/lib64 --with-wxwidgets
--with-blas --with-lapack
So, I have to add: --with-cxx.
And then I have to compile those 2. I just have to run Makefile of the
following directories:
.../grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/vdigit
.../grass-6.4.svn_src_snapshot_2009_12_12/gui/wxpython/nviz
Right? Thanks Martin, that was really helpful
Best regards,
Luis
On Fri, Dec 18, 2009 at 10:55 AM, Martin Landa <landa.martin at gmail.com>wrote:
> Hi,
> 2009/12/18 Luis Lisboa <luislisboa1975 at gmail.com>:
> > Due to the fact that i.class is not available at Windows I decided to
> start
> > using GRASS on Linux.
> > I have just installed and compiled. When I start grass64 I get this
> warning:
> > "WARNING: Vector digitizer is not available (No module named
> > grass6_wxvdigit).
> > Note that vector digitizer is currently not working under MS Windows
> > (hopefully will be fixed soon). Please try more recent version of GRASS."
> > But since I'm now using LINUX :), I don't give a damn about that.
> > But unfortunely, in GIS lay Manager "Start Editing" option is not
> available.
> > And, when I select "Digitizer" at GIS Map Display, I get the following
> > error window
> > " Unable to start vector digitizer.
> > The VDigit python extension was not found or loaded properly.
> > Switching back to 2D display mode
> > Details: No module named grass6_wxdigit"
> > What am I missing because it was suppose to be working..
> > Thanks and happy holidays for everyone.
> You need to compile vdigit extension, see [1].
> Martin
> [1]
> http://trac.osgeo.org/grass/browser/grass/trunk/gui/wxpython/README#L141
> Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20091218/d6a0969f/attachment.html
