[GRASS-user] Wxpython vector digitizer
Fri Dec 18 12:26:50 EST 2009
Martin Landa wrote:
> > ./configure --enable-64bit --with-libs=/usr/lib64 --with-wxwidgets
> > --with-blas --with-lapack
> > So, I have to add:  --with-cxx.
> Also add --with-python switch.
Also, --with-wxwidgets is (AFAIK) only meaningful if you also use
--with-python and --with-cxx.
The wxPython GUI gets "built" (i.e. installed) unconditionally. The
configure switches only affect components which contain C/C++ code
which needs to be compiled.
