[GRASS-user] Gathering all layers, defining subset -- UPDATE
Rich Shepard
rshepard at appl-ecosys.com
Mon Dec 21 18:14:26 EST 2009
On Mon, 21 Dec 2009, Hamish wrote:
> check with v.info, I expect you ended up with an empty map, and a box made
> up of 0,0 0,0 is what is outside the current region.
Hamish
Yes, this is just what happened. What I need to learn is why it happened
when I used v.extract.
The command sequence in my original post may have a clue ... for the
clued.
Thanks,
Rich
