[GRASS-user] Correctly Converting LL to LCC
Hamish
hamish_b at yahoo.com
Mon Dec 28 13:46:29 EST 2009
Hamish:
> > can you cut and paste the whole command line? it gets cut off.
Rich wrote:
> Surprisingly, I cannot copy from the GUI window.
try right-click + copy from the context menu, or a copy button.
then ^V to paste instead of the middle click.
I'm not sure if that's entirely by design or just the way it's working so
far.
the module gui box should have a separate copy button for the command.
re. dbmi error:
did you mess with db.connect at all or are the DB settings original?
what does "db.connect -p" say?
Hamish
