[GRASS-user] extract stream heads
    Markus Metz
    markus.metz.giswork at googlemail.com
    Tue Dec 29 03:55:50 EST 2009
Milton Cezar Ribeiro wrote:
> Dear all,
> I am (finally :-) extracting the drainage from a DEM
> using r.stream.extract. How can I extract also
> the stream heads?
In the vector output of r.stream.extract, stream heads are all points
with stream_type = 'start' in layer 1 or cat = 0 in layer 2. See also
Options, stream_vect in the manual ;-)
Markus M
