[GRASS-user] v.patch: Correct Syntax?
Rich Shepard
rshepard at appl-ecosys.com
Tue Dec 29 19:51:13 EST 2009
I copied (using g.copy) all project maps from the PERMANENT mapset to the
project-specific mapset (a subset of the larger bounds). Next I used
v.in.region to create an area map for the project-specific mapset. Now I
want to clip the vector and raster maps to the bounds of the
project-specific mapset using v.patch. And I've read the man page.
Would the proper syntax be, for example, 'v.patch input=streams,clipbox
out=streams'? Does the order of the maps matter?
I'd like to retain the same map names and attributes, but have the bounds
be those of the smaller region.
Thanks,
Rich
