[GRASS-user] v.in.ascii
Michael Perdue michael_perdue at yahoo.ca
Tue Feb 3 20:53:58 EST 2009
If you create a VRT file for your CSV file, then you should be able to
import it with v.in.ogr directly.
v.in.ogr  dsn=/Users/Desktop/Data/
081211_Mitchell_plane_bores_list_V002.vrt out=mitchell_bores
You VRT file would look like:
<OGRVRTDataSource>
     <OGRVRTLayer name="081211_Mitchell_plane_bores_list_V002">
         <SrcDataSource>081211_Mitchell_plane_bores_list_V002.csv</
SrcDataSource>
         <GeometryType>wkbPoint</GeometryType>
         <LayerSRS>EPSG:26910</LayerSRS>
         <GeometryField encoding="PointFromColumns" x="Easting"
y="Northing"/>
     </OGRVRTLayer>
</OGRVRTDataSource>
Substitute the EPSG code 26910 (NAD83UTM10) for your appropriate
coordinate system and x= & y= to the appropriate column header names.
Mike
On 3-Feb-09, at 2:35 PM, Markus Neteler wrote:
> On Tue, Feb 3, 2009 at 10:29 PM, Harald Hofmann
> <Harald.Hofmann at sci.monash.edu.au> wrote:
>> Sorry Hamish,
>> I replied a little to quickly, I should read the mails to the
>> end ... :-)
>> Yes, I have tried the option colums=. I just thought there is an
>> easier way
>> around.
> There (potentially) is:
> 1. Import table with db.in.ogr (if CSV, create also .csvt file: define
> appropriately
> the types Real, String, Date, Time and/or DateTime):
> http://grass.osgeo.org/grass64/manuals/html64_user/db.in.ogr.html
> If needed, use the "key" parameter to auto-generate a unique key
> column.
> 2. generate a map from the imported table:
> v.in.db
> http://grass.osgeo.org/grass64/manuals/html64_user/v.in.db.html
> If you have many columns this may be quicker (slightly less precise
> concerning
> the column type definitions).
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
