[GRASS-user] Importing ArcASCII raster and associated dbf table?
Devereux, Jarl M Jarl.Devereux at dpi.qld.gov.au
Wed Feb 4 19:28:19 EST 2009
Hi
I'm new to grass and I'm trying to import an ArcASCII raster file with
an associated dbf table into a cygwin grass 6.2.
I have been using r.in.gdal to import the raster without issue however
handling the attribute data is still a mystery to me.
Can I connect a raster to a dbf table or add the attributes as layers?
The db.* commands seemed to be only vector based so I converted the
raster to an area vector using the raster values as the cat. I am not
sure of the steps to copy or attach the arc dbf table. my cat values are
not consecutive and the .dbf table that accompanied the data doesn't
have a "cat" column it has a consecutive "value" column instead. How do
I go about adding this table to the vector so it correctly matches up
"value" and "cat"?
Thanks in advance
Jarl Devereux
********************************DISCLAIMER****************************
The information contained in the above e-mail message or messages
(which includes any attachments) is confidential and may be legally
privileged.  It is intended only for the use of the person or entity
to which it is addressed.  If you are not the addressee any form of
disclosure, copying, modification, distribution or any action taken
or omitted in reliance on the information is unauthorised.  Opinions
contained in the message(s) do not necessarily reflect the opinions
of the Queensland Government and its authorities.  If you received
this communication in error, please notify the sender immediately
and delete it from your computer system network.
