[GRASS-user] xganim tools
Glynn Clements
glynn at gclements.plus.com
Fri Feb 6 21:18:45 EST 2009
Michael Barton wrote:
> >> I tried use xganim for animating a raster files.
> >> http://grass.itc.it/grass62/manuals/html62_user/xganim.html
> >> when I typed xganim, the answer is command not found
> > It is present in 6.4, but GRASS needs to be built with motif/lesstif
> > support for xganim to be there.
> > Install the lesstif2-dev package and "./configure --with-motif"
> A TclTk replacement for xganim is included in GRASS 6.3 and above. It
> is a little nicer than the original and doesn't require motif/lestif.
Note that it's part of gis.m, not a standalone program.
In 7.0, the standalone xganim has been re-written using wxWidgets; it
could probably use some testing.
