[GRASS-user] g.findfile
Martin Landa landa.martin at gmail.com
Tue Feb 10 08:39:44 EST 2009
2009/2/10 Vincent Bain <bain at toraval.fr>:
> Using grass6.4.0svn (revision 35838), the result of g.findfile appears
> not to run properly for raster query :
> create a raster map test,
> run g.findfile element=raster file=test.
> Looks like the file does not exist :
> name=
> mapset=
> fullname=
> file=
> (Tested successfully with a vector map)
> What am I doing wrong ? I remember the command worked in previous
> versions.
use element=cell to find raster map
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa
