[GRASS-user] trace channel from accummulation raster
Markus Metz markus.metz.giswork at googlemail.com
Tue Feb 10 08:50:35 EST 2009
Christoff wrote:
> Hi everybody,
> Is there a way to extract a channels from the accumulation raster, e.g.
> accumulation from r.watershed?
You can either set the threshold option in r.watershed and get stream
segments or use flow accumulation output and do something like r.mapcalc
"channels = if(flow_acc > threshold, flow_acc, null())", threshold would
here be the desired number of cells draining through a given cell when
using r.watershed flow accumulation or size of the area draining through
a given cell for r.terraflow flow accumulation.
See also "Further processing of output layers" in the manual of r.watershed.
> Somehow r.drain delivers something which is not following the accumulation
> raster. In theory the accumulation along the drainage shoult always increase
> and never decrease. My results show a nice increasing trend, which is
> interrupted with very low values.
As I understand, r.drain works on elevation and uses a different
algorithm, so the results are likely different, but I don't know r.drain
that well.
