[GRASS-user] Tips on how to delete areas with no categories?
Moskovitz, Bob
Bob.Moskovitz at conservation.ca.gov
Tue Feb 10 14:40:15 EST 2009
Hello Grass-Users,
After using r.to.vect, I have areas with no categories. These areas appear to be holes. This is what the map look like with info from v.what: http://bobdebm.googlepages.com/example_area.png/example_area-full;init:.png
How do I remove these areas?
Thanks in advance.
Bob
Bob Moskovitz
Research Analyst I
Seismic Hazard Zonation Project
California Geological Survey
http://www.conservation.ca.gov/cgs/shzp<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
CONFIDENTIALITY NOTICE: This communication is intended only for the use of the individual or entity to which it is addressed. This message contains information from the State of California, California Geological Survey, which may be privileged, confidential and exempt from disclosure under applicable law, including the Electronic Communications Privacy Act. If the reader of this communication is not the intended recipient, you are hereby notified that any dissemination, distribution, or copying of this communication is strictly prohibited.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090210/9a14df1c/attachment.html
