[GRASS-user] Tips on how to delete areas with no categories?
Richard Chirgwin
rchirgwin at ozemail.com.au
Tue Feb 10 17:41:22 EST 2009
> Message: 2
> Date: Tue, 10 Feb 2009 11:40:15 -0800
> From: "Moskovitz, Bob" <Bob.Moskovitz at conservation.ca.gov>
> Subject: [GRASS-user] Tips on how to delete areas with no categories?
> To: "Grass-User (E-mail)" <grass-user at lists.osgeo.org>
> Message-ID:
> <A73B6E7A4503E948826CE81A65AF5FECA2A54E at docexs1.ad.consrv.ca.gov>
> Content-Type: text/plain; charset="iso-8859-1"
> Hello Grass-Users,
> After using r.to.vect, I have areas with no categories. These areas appear to be holes. This is what the map look like with info from v.what: http://bobdebm.googlepages.com/example_area.png/example_area-full;init:.png
> How do I remove these areas?
> Thanks in advance.
> Bob
> Bob Moskovitz
> Research Analyst I
> Seismic Hazard Zonation Project
> California Geological Survey
> http://www.conservation.ca.gov/cgs/shzp<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Bob,
What if you use v.category to attach cats to the empty areas, and then
use v.edit to delete the appropriate category range?
Cheers,
RC
