[GRASS-user] Tips on how to delete areas with no categories?
Hamish hamish_b at yahoo.com
Tue Feb 10 18:52:00 EST 2009
Bob Moskovitz wrote:
> > After using r.to.vect, I have areas with no categories.  These areas
> > appear to be holes.
> > How do I remove these areas?
Richard Chirgwin wrote:
> What if you use v.category to attach cats to the empty areas, and then
> use v.edit to delete the appropriate category range?
(or v.dissolve instead of v.edit)
another old trick:
'v.extract cat=1-99999' will only extract actual data, ie will skip holes.
Hamish
