[GRASS-user] updating vector map using another vector map as
criteria
Moritz Lennert
mlennert at club.worldonline.be
Wed Feb 11 10:02:17 EST 2009
On 10/02/09 17:41, Christopher Mire wrote:
> Is there a way I can update the attributes of one vector map, given
> another vector map(vm)?
> The selection vector map would be subset of original vm. As an example,
> using output
> from v.net.path to update a column in original vm, say just updating
> some arbitrary integer
> field to signify that there was a match between original and other vm.
v.distance ... upload=to_attr ... ?
Moritz
