[GRASS-user] db.select and SELECT COUNT query
    Vincent Bain
    bain at toraval.fr
    Wed Feb 11 15:57:44 EST 2009
Sorry for this /stupid/ question (might be time to go to sleep !)
I realize it must be related to a truncature operated between pg and
grass or something like it.
As it was annoying in a recursive query script, I turned the command in
this :
        echo "select count(*) from table1 where attr=201"\
        | db.select 2>/dev/null
Good evening ;-)
Vincent
Le mercredi 11 février 2009 à 21:36 +0100, Vincent Bain a écrit :
> Hi,
> has anybody ever had this kind of message ?
> Working on grass6.4.0svn, considering a database connection through the
> pg driver ; in order to count records matching an attribute (attr) value
> I execute this command on a table (table1) linked to a vector map :
>          echo "select count(*) from table1 where attr=201" | db.select
> The result should be 3. And db.select returns :
>         ATTENTION : column 'count' : type int8 (bigint) is stored as
>         integer (4
>                     bytes) some data may be damaged
>         count
>         3
> In the end, it returns the result, but what does this message mean ?
> (Of course the same instruction given at the psql prompt raises no
> special warning).
> Any idea ?
> Thank you in advance,
> Vincent.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
