[GRASS-user] executing multiple commands at once
Renae Mackas rmackas at sfu.ca
Thu Feb 12 13:33:40 EST 2009
Thanks Markus, I will give those a try.
Markus Neteler wrote:
> On Wed, Feb 11, 2009 at 9:17 PM, Renae Mackas <rmackas at sfu.ca> wrote:
>> Hi-
>> I am new to GRASS (using version 6.3.0), and am trying to figure out how
>> to
>> execute multiple commands at once in the command line.  I am currently
>> tring
>> to import many LANDSAT image files as rasters, and it would make it a lot
>> easier/faster if I could import more than one at a time.  Most of the
>> online
>> examples I have found show that people are able to do this, but I am
>> still
>> not aware how to do so.  Any tips would be much appreciated.
> I usually use a shell script for this, in a "for" loop I get
> in all files.
> Example:
>  http://www.grassbook.org/examples_menu3rd.php
>  -> Scripts to bulk import LANDSAT-TM5/LANDSAT-TM7 scenes
>      from GLCF Maryland into GRASS
>     -> download
> You can easily adapt those scripts to your needs.
> Markus
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/executing-multiple-commands-at-once-tp2311081p2316687.html
Sent from the Grass - Users mailing list archive at Nabble.com.
