[GRASS-user] Thiessen Polygons
Glynn Clements
glynn at gclements.plus.com
Fri Feb 13 09:08:41 EST 2009
Jan Hartmann wrote:
> > The problem with using r.cost is that you would need to know the cost
> > for each cell before you have created the polygons.
> > I think that the simplest accurate approach would be to modify
> > r.grow.distance.
> Do you mean: adding a metric parameter to Euclidean, Squared, Manhattan,
> and Maximum? Something like: compute on the basis of the value of
> traversed cells?
I mean scale the distance by the value of the nearest non-null cell.
