[GRASS-user] Thiessen Polygons
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Sat Feb 14 11:16:14 EST 2009
Dear Glynn Clements
Is there a command r.grow.distance on GRASS?
I tryed to find it on Native WinGrass, but it appears not be available,
almost on 6.3 version.
Best wishes
miltinho
2009/2/14 Glynn Clements <glynn at gclements.plus.com>
> Jan Hartmann wrote:
> > With that in mind, if the algorithm you propose would be indeed an
> > approximation to weighted Voronoi polygons, *and* it wouldn't be all to
> > hard to implement (I have no idea about that), would it make sense to
> > propose this as a new RFC for GRASS?
> Oops; I spoke too soon.
> In retrospect, this won't work. r.grow.distance relies upon the fact
> that once a cell falls out of consideration, it stays out. It will
> only consider cells which either are from the current row, or were
> used on the previous row.
> With distance scaling, this doesn't hold. A cell could be temporarily
> overriden by much nearer cells with increased scale factors (lower
> weights), then regain its influence once the distance increases.
> IOW, this isn't something which can implemented given the algorithm
> used by r.grow.distance. Any algorithm which implemented distance
> scaling would inevitably have worst-case memory usage proportional to
> the number of non-null input cells, as you can never "forget" a cell
> whose scale factor is lower than those currently being considered, as
> it will eventually regain its influence.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090214/9ef20abf/attachment.html
