[GRASS-user] edges in basin map from r.watershed
MS mseibel at gmail.com
Sun Feb 15 09:50:43 EST 2009
IMO the esri term of a filled DEM being "hydrologically correct" is a
misnomer.
Natural terrain has real depressions that impact surface water flow.
Big depressional wetlands can retain water and release via groundwater
or evapotranspiration.
I like how r.watershed acomodates known depressions and handles the
flow as interception. Also, then one can use other tools to find
problematic areas in a raw DEM.  I modeled an internally drained basin
using known depressions in GRASS, and it worked fantastic.
One problematic example for esri is modeling an internally drained or
sink-watershed.  These have no surface water outlet.  If one filled it
to get flow out of a 9 sq. mile watershed, the esri analyses are then
meaningless.  Which is one reason why filling a dem just to get an
esri module to work and calling the DEM "hydrologically correct" is a
misnomer an a limitation.
Mark
On Feb 13, 2009, at 11:09 AM, Markus Metz <markus.metz.giswork at googlemail.com
 > wrote:
> Christian Schwartze wrote:
>> Dear GRASS users,
>> with r.watershed I get strange basin boundaries for some areas und
>> I'm not able
>> to give account of it. Attached you can find that part of the basin
>> map which
>> looks curiously. I means the sharp-edged regions...
>> Whats the reason?
> This is most probably a flat area (no slope). Flow direction, flow
> accumulation, stream segments and basins can not reasonably be
> calculated for flat areas, these are regarded as missing information
> and some assumption has been made by the algorithm.
> What could help is to use a raster DEM as input that is *not*
> filled, some would say not hydrologically correct, but r.watershed
> works better with the raw, not filled DEM.
> What could also help, if this does not work or it really is a flat
> area, is r.watershed of grass7 with multiple flow direction. Note
> that the result may look nicer, but it still holds true that
> drainage direction (and therefore all other output) has to be
> estimated for flat areas. The A * Search of r.watershed is doing a
> pretty good job, and multiple flow accumulation can improve it a bit
> more, within limits.
>> Basis is an Arc Info .adf raster file for DEM data.
> I think Arc Info wants a depressionless, filled, hydrologically
> correct DEM. r.watershed does explicitely not want such a DEM, it
> wants a raw DEM with depressions, not filled, and not hydrologically
> correct.
> I hope that helps,
> Markus M
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
