[GRASS-user] Problemas con winGRASS 6.4.0RC3 del instalador
Jarek Jasiewicz
jarekj at amu.edu.pl
Sun Feb 15 14:41:36 EST 2009
I confirm that error on old latlong location (created over 1 years ago,
I didn't use it since that time)
due to this error gis.m cannot start, but grass still working in the
text mode Addational masage in text console are:
Error in startup script: can't read "monitor_zooms(1,1,n)": no such
variable
while executing
"lappend region $monitor_zooms($mon,1,$attr)"
(procedure "MapCanvas::currentzoom" line 15)
invoked from within
"MapCanvas::currentzoom $mon"
(procedure "MapCanvas::coordconv" line 23)
invoked from within
"MapCanvas::coordconv $mon"
(procedure "MapCanvas::create" line 68)
invoked from within
"MapCanvas::create"
(procedure "Gm::startmon" line 11)
invoked from within
"Gm::startmon"
(procedure "Gm::create" line 79)
invoked from within
"Gm::create"
(procedure "main" line 30)
invoked from within
"main $argc $argv"
(file "/usr/local/grass-6.4.svn/etc/gm/gm.tcl" line 566)
Jarek
Marilena Yeguez pisze:
> Saludos, me anime a descargar el instalador OSGeo4W que trae GRASS
> para Windows entre muchas otras cosas, tal como me recomendaron. Lo
> instalé y al abrir GRASS me dio un error al no estar predefinido el
> directorio de datos, estuve revisando a ver si encontraba una carpeta
> que el instalador creara para tal fin, pero no la halle, realmente la
> crea?...Decidí crear mi propio directorio, copie una locación de
> prueba, pero GRASS me arroja el siguiente error:
> Erro setting region (Problem with g.region?): child lilled:unknown signal
> Agradezco a quien pueda ayudarme...
> Marilena
> Get news, entertainment and everything you care about at Live.com.
> Check it out! <http://www.live.com/getstarted.aspx>
> Invite your mail contacts to join your friends list with Windows Live
> Spaces. It's easy! Try it!
> <http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us>
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
