[GRASS-user] create raster from line vector
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Mon Feb 16 10:00:07 EST 2009
On Mon, 2009-02-16 at 15:52 +0100, Nikos Alexandris wrote:
> On Mon, 2009-02-16 at 15:40 +0100, G. Allegri wrote:
> > I share my vector, if someone wants to reproduce this problem:
> > http://www.geospatial.it/allegri/bordi.tar.gz
> > EPSG:32632
> Giovanni,
> the shapefile's attribute table looks messed up. I just opened it with
> QGIS and the column names are senseless characters. In addition, all
> rows are filled with NULL.
> I don't know it's just a "codepage" sort of problem or the reason for
> your empty raster.
> I will try with GRASS now. If I'll find something useful I'll post back.
Sorry, I can't even read it with ogrinfo.
ogrinfo /home/nik/Desktop/in/bordi.shp -al | head -100
ERROR 3: fread(65004) failed on DBF file.
INFO: Open of `/home/nik/Desktop/in/bordi.shp'
      using driver `ESRI Shapefile' successful.
Layer name: bordi
Geometry: Line String
Feature Count: 9
Extent: (1009114.847644, 4446909.136474) - (1312106.717266,
4668313.355348)
Layer SRS WKT:
PROJCS["WGS_1984_UTM_Zone_32N",
    GEOGCS["GCS_WGS_1984",
        DATUM["WGS_1984",
            SPHEROID["WGS_1984",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["Degree",0.017453292519943295]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",9],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",0],
    UNIT["Meter",1]]
��N���nL at Q: String (17.0)
L$D=�u����: String (207.0)
�: String (191.0)
��GMI�FYYY: String (78.0)
'6:�+JX�fW`: String (235.0)
g��ʚ*;
: String (243.0)
_"*gD88Z��: String (109.0)
2U]「��@QU�: String (119.0)
�'@TN�]����: String (223.0)
�魗n�676t: String (117.0)
+&<JWv���: String (136.0)
����\��: String (212.0)
o����7ʤ��: String (247.0)
<�_\
��: String (126.0)
ˆøßøŒÿÛù¯L: S├⎼␋┼± (207.0)
;4OÓÓÐà4´Þ: S├⎼␋┼± (32.0)
B8¬┘┴šì¶%þ¿: S├⎼␋┼± (33.0)
dž¸˜øæ%¬?│: S├⎼␋┼± (200.0)
# it continues like that :-(
