[GRASS-user] create raster from line vector
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Mon Feb 16 10:09:53 EST 2009
On Mon, 2009-02-16 at 16:00 +0100, Nikos Alexandris wrote:
> > > I share my vector, if someone wants to reproduce this problem:
> > > http://www.geospatial.it/allegri/bordi.tar.gz
> > > EPSG:32632
It works now. No problem.
Cheers, Nikos
> history
1 v.in.ogr dsn=/home/nik/Desktop/in/bordi.shp out=testbordi
2 d.mon x0
3 g.region vect=testbordi
4 g.region vect=testbordi -pa
5 d.vect testbordi
6 v.info testbordi
7 v.to.rast testbordi out=testbordirast use=val value=1
8 d.rast -o testbordirast
9 r.info testbodirast
10 r.info testbordirast
11 history
# r.info
r.info testbordirast -hgr
min=1
max=1
north=4668313.355348
south=4446909.136474
east=1312106.717266
west=1009114.847644
Data Source:
Vector Map: testbordi in mapset PERMANENT
Original scale from vector map: 1:1
Data Description:
generated by v.to.rast
Comments:
v.to.rast input="testbordi" output="testbordirast" use="val" type="p\
oint,line,area" layer=1 value=1 rows=4096
