[GRASS-user] Problemas con winGRASS 6.4.0RC3 del instalador
Markus Neteler
neteler at osgeo.org
Mon Feb 16 13:59:34 EST 2009
On Mon, Feb 16, 2009 at 6:05 PM, Jarek Jasiewicz <jarekj at amu.edu.pl> wrote:
> g.region says:
> EROR:Invalid ellipsoid '� ' in file PROJ_INFO in <PERMANENT>
How was the PROJ_INFO file generated?
Which projection?
> I removed PROJ_INFO and now grass can be used in gui (gis.m) mode
> thanks for tip
It's no good to remove the file since you lose the spatial
reference. Better to actually correct it...
Markus
