[GRASS-user] Export specific shapes from a vector file
    leonidas
    leonidas_liakos at yahoo.gr
    Mon Feb 16 16:14:04 EST 2009
Thank you Niko,
well I understand the first one (using v.extract).
-Is it possible to do something like that using v.out.ogr and export to
shapefile?
-As far as concerns the second question using v.to.rast, how can I export
only specific areas using sql where clause or list for specific categories?
Thanks again, Leonidas
Nikos Alexandris wrote:
> On Mon, 2009-02-16 at 12:55 -0800, leonidas wrote:
>> I need to export specific shapes from a grass vector file to another
>> grass
>> vector file.
> v.extract in=VectorMap out=ExtractedFeatures ...
> # you can use "list=" to extract specific categories (the "cat" column)
> # or an SQL where clause, e.g. something like
> "where='SomeColumn="SomeString"'
>> Also, I need to convert specific polygons from a vector grass file to a
>> raster grass file.
> I assume by polygons you mean areas.
> v.to.rast in=VectorMap out=RasterMap type=area ...
> # "use=???" You need to decide which values you will assign to your
> pixels.
>> How can I do that?
>> Thanks, Leonidas
> Regards, Nikos
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Export-specific-shapes-from-a-vector-file-tp2337165p2337293.html
Sent from the Grass - Users mailing list archive at Nabble.com.
