FW: [GRASS-user] unable to install Grass
Jimmy Maro jimmy.maro at nari.org.pg
Wed Feb 18 20:25:16 EST 2009
Hamish,
Exact error msg: Unable to setup.ini from <http://www.osgeo.org/osgeow4>
We have a proxy server which allows internet through Web proxy username and
password. I m able to get thru this OK.
Problem occurs after I started running installation. Should I be running
installation through dos prompt?
Advice pls.
Ta,
Jimmy
-----Original Message-----
Sent: Thursday, February 19, 2009 10:07 AM
To: grass-user at lists.osgeo.org; Jimmy Maro
Subject: RE: FW: [GRASS-user] unable to install Grass
Jimmy wrote:
> Still no luck!!
what does the (exact) error message say now? same but without typo?
does your proxy server require a username and the installer doesn't
give you an option to enter that?
for what it's worth, there does appear to be a setup.ini file in:
  http://download.osgeo.org/osgeo4w/
I haven't tried to run the OSGeo4W installer myself yet, so I'm just
guessing...
Hamish
No virus found in this incoming message.
Checked by AVG.
Version: 7.5.552 / Virus Database: 270.10.25/1957 - Release Date: 2/17/2009
7:07 AM
