[GRASS-user] vector area needs water fill
Nikos Alexandris
nikos.alexandris at felis.uni-freiburg.de
Wed Feb 18 23:39:36 EST 2009
Kurt:
> I am almost sure that I can trace the areas in qgis I made a test
> with its drawing tools. Is there a way to import that tracing back to
> GRASS?
Kurt, if you mean to import them in GRASS, sure, why not? I suppose by
trace you mean you have created a vector map (shapefile probably). You
can either select the layer in your legend, save as Shapefile and then
v.in.ogr to import in GRASS _or_ you can use the GRASS-toolbox within
from QGIS.
Except if I misunderstand what you mean by trace.
Regards, Nikos
