[GRASS-user] improve v.rast.stats speed?
Markus Metz markus.metz.giswork at googlemail.com
Thu Feb 19 10:10:51 EST 2009
Markus Neteler wrote:
> On Thu, Feb 19, 2009 at 2:20 PM, G. Allegri <giohappy at gmail.com> wrote:
>> Thanks for the ideas.
>> I've just tried Starspan but it's performance is still too slow. I've
>> let it run for 15 minutes...
> Can you please try GRASS 7?
> grass70/scripts/v.rast.stats/v.rast.stats.py
grass70/scripts/v.rast.stats/v.rast.stats.py also uses r.mapcalc in
every pass:
for i in cats:
    grass.mapcalc("MASK = if(...)
if v.rast.stats is faster in grass7, then probably because of improved
raster libs. A speed increase from >5 hours to 40 seconds is unlikely
since grass.mapcalc is still called 1793 times (assuming each area has a
unique category) for a region with 4415x6632 cells...
