[GRASS-user] Re: improve v.rast.stats speed?
Markus Metz markus.metz.giswork at googlemail.com
Fri Feb 20 02:30:55 EST 2009
Hamish wrote:
> Markus Metz:
>> r.univar2.zonal does zonal statistics
> pssst- "svn copy" not "svn add". It works between -addons and trunk.
Done, hopefully now the right way. Segfault fixed, only 2D zoning, no 3D
zoning. Zone number and category label if present are printed before the
stats are printed. -g and -e flags supported as before. Output can be
written to a file for easier digesting.
Maybe someone has use for it. It's good to get stats e.g. per land-cover
type, or also to do a manual v.rast.stats alternative.
Written against develbranch_6, so it should work with 6.4 and 6.5.
svn co https://svn.osgeo.org/grass/grass-addons/raster/r.univar2.zonal
r.univar2.zonal
in a hurry,
Markus M
