[GRASS-user] Calculating eigen values and % variance
explainedafter PCA analysis
Wesley Roberts
wroberts at csir.co.za
Wed Feb 25 08:36:41 EST 2009
I will download and compile 6.4 from source and give the addon a go. Will get back to on the outcome.
Installed Fort77 and f2c as per your suggestion.
Many thanks,
Wesley
>>> Nikos Alexandris <nikos.alexandris at felis.uni-freiburg.de> 02/25/09 3:31 PM >>>
Wesley:
> I see that I would need to upgrade to 6.4 using svn. I currently
> install using synaptic, does this mean I need to compile from source
> and then add the m.eigensystem addon?
> Not sure about f77, is this a fortran compiler? I have gfortran
> compiler version 4.2.3, will this do?
(@Hamish: apologies for the interference :-p)
Wesley,
perhaps it's better to upgrade to 6.4 (or why not to grass6_devel =
grass65 ?). grass needs to be compiled first (don't install), then
compile m.eigensystem and install in the end grass.
I don't know if gfortran will help you. But you can install fort77 and
f2c under ubuntu:
# from "apt-cache search fort77"
f2c - A FORTRAN 77 to C/C++ translator
fort77 - Invoke f2c like a real compiler
If you have success running m.eigensystem, can I please ask you to let
the list (and me :-p) know about it? I compiled m.eigensystem without
errors but it doesn't seem to work within from grass65. I am currently
re-compiling grass6_devel to see whether it will work or not.
Or do I need to work with grass6.4?
Kind regards, Nikos
This message is subject to the CSIR's copyright terms and conditions, e-mail legal notice, and implemented Open Document Format (ODF) standard.
The full disclaimer details can be found at http://www.csir.co.za/disclaimer.html.
This message has been scanned for viruses and dangerous content by MailScanner,
and is believed to be clean. MailScanner thanks Transtec Computers for their support.
