[GRASS-user] qgis + grass-plugin = gdal-problem (update)
achim ak7 at jupiter.uni-freiburg.de
Fri Feb 27 07:39:54 EST 2009
I used the goe-repository files for installing grass (6.4) and grass63.
Do I have to compile myself? Cant I clean old libraries by myself and
reinstall grass from the repository?
Thanks,
achim
Nikos Alexandris schrieb:
> On Fri, 2009-02-27 at 11:47 +0100, achim wrote:
>> Correction:
>> achim schrieb:
>>> Hallo,
>>> starting qgis(1.0.1) with grass64 I can open a grass location, but when
>>> I open a rastermap, qgis terminates with following error:
>>> qgis: symbol lookup error: /usr/lib/gdalplugins/gdal_GRASS.so: undefined
>>> symbol: G_no_gisinit
>>> When I start qgis with grass63 installed, qgis terminates immediately
>>> with the same error.
>> sorry: not the same error:
>> qgis: symbol lookup error: /usr/lib64/libqgisgrass.so.1.0: undefined
>> symbol: G__no_gisinit
>>> Any idea why?
>>> achim
> If you compiled grass64 then have a look in the mail-archive for
> "G__no_gisinit". I had the problem myself and it has been discussed some
> times. It's probably a bad linking issue. I would recommend to clean
> your system from old libraries. Then, proper compilation and
> installation should give you the solution.
> Kind regards, Nikos
