[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
Kenneth Brookes
ken_brookes at hotmail.com
Sat Jan 3 13:54:41 EST 2009
I used the WinGRASS 6.3.0-4 Setup.exe to install GRASS on Vista from July 19,
2008.
K. Brookes
Michael Barton wrote:
> On Jan 3, 2009, at 6:47 AM, <grass-user-request at lists.osgeo.org> wrote:
>> Date: Sat, 3 Jan 2009 07:43:17 +0100
>> From: "Markus Neteler" <neteler at osgeo.org>
>> Subject: Re: [GRASS-user] Display thematic vector map - WinGRASS 6.3
>> (Vista)
>> To: "Ken Brookes" <ken_brookes at hotmail.com>
>> Cc: Grass GIS Users List WinGRASS User <grass-user at lists.osgeo.org>
>> Message-ID:
>> <86782b610901022243o54070b91q3a5802660186b5b0 at mail.gmail.com>
>> Content-Type: text/plain; charset=ISO-8859-1
>> On Fri, Jan 2, 2009 at 10:03 PM, Ken Brookes
>> <ken_brookes at hotmail.com> wrote:
>>> Hello
>>> I'm a GRASS GIS novice and have recently downloaded and successfully
>>> installed GRASS 6.3.0 directly onto MS-Windows Vista. I have been
>>> playing
>>> with the GIS manager GUI and have run into a problem trying to create
>>> thematic Vector maps and display them in the map display. I am
>>> using the
>>> North Carolina data set (example data set provided) and a variety
>>> of vector
>>> maps to try and create graduated color, point and line maps to get
>>> a feel of
>>> how it works. I have been adding the thematic layer and specifying
>>> all the
>>> parameters correctly in the GUI. The actual binning of the numeric
>>> data is
>>> occurring properly because a new window will pop-up with the correct
>>> legend for the parameters specified, however nothing will display
>>> in the map
>>> display window. I do get a message in the command line shell saying
>>> "No such
>>> monitor exists 'PNG' ". I've tried to run d.vect.thematic through the
>>> command line shell and get an error saying "must open display
>>> monitor". I'm
>>> not sure what the problem is. Can anyone help?
>> The problem is that winGRASS does not support X or PNG monitors.
>> The solution is the new Python based user interface.
>> I am not sure if there is a d.vect.thematic equivalent already (we are
>> preparing 6.4.0 these days) which work on Windows since I am no
>> Windows user.
>> I hope you get the answer from another group member.
>> Markus
> GRASS does support PNG monitors in winGRASS (or the TclTk canvas
> wouldn't work). There was a bug that caused problems with winGRASS and
> thematic mapping last Spring. I don't remember what it was, but
> thought it was fixed. What is the compile date of your version of
> GRASS 6.3?
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://n2.nabble.com/Re%3A-Display-thematic-vector-map---WinGRASS-6.3-%09%28Vista%29-tp2106336p2106615.html
Sent from the Grass - Users mailing list archive at Nabble.com.
