[GRASS-user] Problems with compiling addon r.uslek
Christian Braun christian.braun at tudor.lu
Mon Jan 5 10:47:41 EST 2009
Hi list members,
I tried to compile a GRASS Addon called r.uslek.
I compiled a fresh svn checkout of GRASS 6.4 and downloaded afterwards
the addon code and put into a subfolder of the svn source code.
With the following statement I get the error beneath...
I never did this procedure before. I have the workflow from the WIKI (http://grass.osgeo.org/wiki/Compile_and_Install#Addons
  - last point)
Any ideas?
Thanks in advance,
Christian
> cbraun at ubuntu:/usr/local/src/grass_64_svn/addons/r.uslek$ sudo make
> MODULE_TOPDIR=/usr/local/src/grass_64_svn/
> mkdir -p @GRASS_HOME@/bin. at host@
> mkdir -p @GRASS_HOME@/dist. at host@/include/grass
> mkdir -p @GRASS_HOME@/dist. at host@/lib
> mkdir -p @GRASS_HOME@/dist. at host@/bin
> mkdir -p @GRASS_HOME@/dist. at host@/etc
> mkdir -p @GRASS_HOME@/dist. at host@/driver
> mkdir -p @GRASS_HOME@/dist. at host@/driver/db
> mkdir -p @GRASS_HOME@/dist. at host@/fonts
> test -d OBJ. at host@ || mkdir -p OBJ. at host@
> /bin/sh: CC@: not found
> make: *** [OBJ. at host@/main.o] Error 127
