[GRASS-user] v.in.dxf lines with no elevation
Huidae Cho
grass4u at gmail.com
Mon Jan 5 23:03:09 EST 2009
Hi Adam,
Can I take a look at the dxf file you tried?
Thanks.
Huidae
On Mon, Jan 05, 2009 at 06:02:54PM -0800, Adam Dershowitz wrote:
> I have a dxf file that contains both lines and points. If I import it into
> grass with v.in.dxf the lines end up at an elevation of 0, while the points
> show up correctly. I have verified that the lines do in fact have an elevation
> by importing the dxf both into google sketch up and blender as a test.
> I googled around some and it seems like it used to be necessary to run
> v.in.dxf3d but I can't find that, and it appears that it was just incorporated
> into v.in.dxf, best I can tell.
> Any suggestions for getting the lines to the correct elevation?
> Thanks,
> --Adam
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
