[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
Moritz Lennert
mlennert at club.worldonline.be
Tue Jan 6 12:51:52 EST 2009
On 06/01/09 17:51, Michael Barton wrote:
> Thanks for the correction. WinGRASS supports PNG output, not a monitor.
> d.vect.thematic was rewritten to use direct rendering through PNG, so it
> should work on Windows.
This was done in 6.4, so it is not available in winGRASS, yet, which is
based on 6.3. Just replacing the script doesn't work, either as it use
the fs= parameter of v.db.connect which wasn't introduced until 6.4.
So, another strident call for the a 6.4 winGRASS.
Moritz
