[GRASS-user] v.centroids and cat values
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Tue Jan 6 15:28:49 EST 2009
GRASS modules that create area type features should already be generating
centroids and adding categories to them automatically, shouldn't they?
As far as I am aware, e.g., v.in.ogr does this, so we are talking mainly
about adding centroid generation to the interactive digitizing tool, aren't we?
The GRASS Vector lib API should have a function that finds a good centroid automatically.
Or am I misled here (guess I am getting a bit confused myself, now)?
To be quite honest, I have always been a bit bewildered about the choice
of using a centroid point for linking attributes to area features.
Could anyone here fill me in on what advantage that has?
Cheers (and a good New Year, btw.),
Ben
Michael Barton wrote:
> On Jan 6, 2009, at 10:00 AM, <grass-user-request at lists.osgeo.org> wrote:
>> Date: Tue, 06 Jan 2009 17:19:58 +0100
>> From: Moritz Lennert <mlennert at club.worldonline.be>
>> Subject: Re: [GRASS-user] v.centroids and cat values
>> To: Micha Silver <micha at arava.co.il>
>> Cc: GRASS user list <grass-user at lists.osgeo.org>
>> Message-ID: <496384AE.4000204 at club.worldonline.be>
>> Content-Type: text/plain; charset=UTF-8; format=flowed
>> On 03/01/09 17:29, Micha Silver wrote:
>>> I'd like to better understand the way cat values are assigned to
>>> centroids when using v.centroids. I came across a problem when I created
>>> a new vector and digitized boundaries (v.digit -n) . Before beginning
>>> to digitize, I added some columns to the attribute table within v.digit,
>>> so that on completing each feature, I could fill in the values for that
>>> feature. I had one column for the label, and one column, GRASSRGB for
>>> coloring. I did not bother to digitize centroids, but rather, after
>>> completing the boundaries, and exiting v.digit, I ran v.centroids.
>>> I was surprised to see that the cat value assigned to each centroid
>>> *does not correspond* to the cat values of the surrounding boundary.
>>> This has the unfortunate effect of showing incorrect labels when running
>>> d.vect with the display=shape,attr option, since the attribute is taken
>>> from centroid, and not from its surrounding boundary. In addition, when
>>> coloring with the d.vect -a option, the boundaries get the correct color
>>> from the GRASSRGB column, but the fill color is also wrong, since the
>>> fill color is again taken from the attributes of the centroid. And the
>>> centroid, with a different cat value, goes to the wrong row of the
>>> attached attribute table. This behavior is certainly undesirable,
>>> unless I'm missing something basic??
>>> My workaround was to delete all centroids, then go back into v.digit,
>>> and digitize each centroid, while being careful to choose it's cat value
>>> manually, and set each one to the correct cat of the surrounding
>>> boundary by choosing "Manual Entry" instead of "Next not used" mode for
>>> categories.
>>> So, is there some way to create centroids, such that they automatically
>>> get the same cat value as the boundary?
>> Normally, the "best practice" is to digitize boundaries without category
>> values (unless you specifically want information concerning the
>> boundary, not the area it contains) and then digitize the centroids with
>> category values and relevant attribute data.
>> In your case, the easiest way out would seem to be v.distance, i.e.:
>> - v.centroid in=YourBoundaries out=YourMap
>> - v.db.addcol YourMap column="b_cat int"
>> - v.distance from=YourMap from_type=centroid to=YourMap to_type=boundary
>> upload=cat column=b_cat #this should find the nearest boundary for each
>> centroid
>> - v.category in=YourMap out=YourMap2 option=del type=boundary
>> - v.reclass in=YourMap2 out=YourMap3 type=centroid column=b_cat
>> - db.copy from_table=YourMap2 to_table=YourMap3
>> - db.dropcol YourMap3 col=b_cat
>> - Now you should have a YourMap3 with centroids that are linked to the
>> correct attributes. If this is the case, you can safely do the next step:
>> - g.remove vect=YourMap,YourMap2
>> This should be quite easy to make into a script module, or maybe extend
>> v.centroids to optionally do this for you.
> I still think that when an area is created, a centroid should
> automatically be placed at some standard and logical place for each
> area. Area centroids should be an integral component of area topology,
> not a separate point that must be manually placed and manipulated.
> Michael
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Benjamin Ducke
Senior Applications Support and Development Officer
Oxford Archaeological Unit Limited
Janus House
Osney Mead
OX2 0ES
Oxford, U.K.
Tel.: ++44 (0)1865 263 800
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
