[GRASS-user] Datum in new grass location
Markus Neteler
neteler at osgeo.org
Sat Jan 10 05:26:18 EST 2009
On Sat, Jan 10, 2009 at 10:38 AM, edmondo.elisei
<edmondo.elisei at gmail.com> wrote:
> Dear All,
> I'm using GRASS 6.3 (both linux and Win) and I need to reprojecting
> raster data from Lat/Long WgS84 to UTM33N ED50.
> I've defined a new location for UTM33-N ED50 with the corresponding EPSG
> code (23033), but grass has reported this alert"
> g.proj: WARNIG: DATUM unknown not recognized by grass and no parameters
> found".
GRASS 6.4.svn (spearfish60):~ > g.proj -c epsg=23033 location=ed50
Location ed50 created!
GRASS 6.4.svn (spearfish60):~ > exit
grass64 ~/grassdata/ed50/PERMANENT/
GRASS 6.4.svn (ed50):~ > g.proj -w
PROJCS["UTM Zone 33, Northern Hemisphere",
GEOGCS["international",
DATUM["European_Datum_1950",
SPHEROID["International_1924",6378388,297]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",15],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",0],
UNIT["metre",1]]
Looks good to me.
> So, the new location datum is by default WGS84, not ED50.
> it's a bug or I wrong anything?
Which was your command to generate it?
Markus
