[GRASS-user] Display thematic vector map - WinGRASS 6.3 (Vista)
Michael Barton
michael.barton at asu.edu
Wed Jan 14 23:22:04 EST 2009
I'm pretty sure that this is a Vista issue, though one that has been
solved in 6.4.
Michael
On Jan 14, 2009, at 7:33 PM, Matt wrote:
> Ken,
> You are not alone. I tried the thematic vector example on page 171 of
> Neteler & Mitasova and also encountered the "You must open a display
> monitor" message. I'm running 6.3.0-4 on Vista.
> Matt
> On Tue, Jan 6, 2009 at 12:51 PM, Moritz Lennert
> <mlennert at club.worldonline.be> wrote:
>> On 06/01/09 17:51, Michael Barton wrote:
>>> Thanks for the correction. WinGRASS supports PNG output, not a
>>> monitor.
>>> d.vect.thematic was rewritten to use direct rendering through PNG,
>>> so it
>>> should work on Windows.
>> This was done in 6.4, so it is not available in winGRASS, yet,
>> which is
>> based on 6.3. Just replacing the script doesn't work, either as it
>> use the
>> fs= parameter of v.db.connect which wasn't introduced until 6.4.
>> So, another strident call for the a 6.4 winGRASS.
>> Moritz
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
