[GRASS-user] DEM CGIAR
Markus Neteler
neteler at osgeo.org
Thu Jan 15 13:40:19 EST 2009
On Thu, Jan 15, 2009 at 2:41 PM, Edmondo Elisei
<edmondo.elisei at gmail.com> wrote:
> the output of g.proj for my UTM33 N location:
> PROJCS["UTM Zone 33, Northern Hemisphere",
> GEOGCS["international",
> DATUM["European_Datum_1950",
> SPHEROID["International_1924",6378388,297],
> TOWGS84[-87.000,-98.000,-121.000]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["latitude_of_origin",0],
> PARAMETER["central_meridian",15],
> PARAMETER["scale_factor",0.9996],
> PARAMETER["false_easting",500000],
> PARAMETER["false_northing",0],
> UNIT["metre",1]]
Looks ok to me. If also the LatLong is ok, then probably
your other data you compare to are shifted?
Markus
