[GRASS-user] g.rename & wx GUI
Martin Landa landa.martin at gmail.com
Sun Jan 18 12:32:36 EST 2009
2009/1/18 Paolo Craveri <pcraveri at gmail.com>:
> 1)add vector  map layer and set some properties
> 2)display it in map display
> 3)rename the vector (command line: g.rename vect...)
> 4)Re-render map in map display
> 5)get error msg "... Details:
> Error: Vector map <pti at area> not found"
> 6)in Layer Manager ->properties ->"Name of imput vector map" set the
> new name of vector map
> 7)try re-render map display: get nothing.
> 8)To display vector map (which is just  renamed) I have to remove
> vector layer from Gis Layer Manager (lost all setting properties) and
> re-add.
fixed in r35482.
> Is it possible to avoid point 8 (map display refresh with the same
> vector with new name)?
I was thinking to design dialog for managing data layers (copy,
rename, remove) with optional update of Layer tree (rename, remove).
But I am going to be busy and I am afraid it will be not better till
June. Any volunteer? ;-)
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
