[GRASS-user] Original location: How to create from the command
	line ?
    Moritz Lennert
    mlennert at club.worldonline.be
    Mon Jan 19 11:37:07 EST 2009
On 19/01/09 17:16, Glynn Clements wrote:
> "Peter Löwe" wrote:
>>>> is there an (easy) recipe to create a completely new location from
>>>> scratch without using a GUI ?
>>>> To be precise: If GRASS is started for the first time in "-text" mode
>>>> (=no GUI) ** without having a sample location like Spearfish or North
>>>> Carolina around**, how can location parameters (projection, extent,
>>>> EPSG...) be handed over to set up a very first location ?
>>> Just type in the name of the location you want to create and GRASS will
>>> prompt you for the parameters.
>> That's true. But is there also a way to provide the parameters
>> _without_ interaction with the user (-> GRASS scripting & automation)
> You can create a new location and mapset with "g.proj -c ...", then
> make it current with g.mapset. But those are GRASS commands, and only
> work within GRASS.
I imagine that you can create your own location by having a script
create the location directory, the PERMANENT mapset directory and the
PROJ_INFO, DEFAULT_WIND and PROJ_UNITS files, or ?
Moritz
