[GRASS-user] Draping map
    Tom van der Putte
    tom at vdputte.nl
    Tue Jan 20 04:07:01 EST 2009
Hi Edmondo,
If I get your question correctly:
Resampling data with a spatial resolution of 90m might increase the
resolution of the DEM itself , but it will not increase the detail of the
data, only the number of pixels in your DEM. For instance, when you
downscale an image of 1 x 1 pixel by a factor 2 (both in x and y direction),
the new image will consist of four pixels (2x2). Which all have the same
value as the original 1 pixel. So although the number of pixels has been
increased, the detail remains the same.
So in the end there is not much to do about it.
Regards, Tom
[mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of Edmondo Elisei
Sent: dinsdag 20 januari 2009 9:50
To: GRASS user list
Subject: [GRASS-user] Draping map
I've a DEM with 90m resolution and a tif map (1 m res).
In draping the tif on my dem the resultant map in nviz has a very low
quality.
I tried changing the resolution of the DEM (r.resamp) in order to have the
same than tif, but I didn't obtain improvements.
Any advice?
Thanks
regards
Geen virus gevonden in het binnenkomende-bericht.
Gecontroleerd door AVG - http://www.avg.com
Versie: 8.0.176 / Virusdatabase: 270.10.9/1902 - datum van uitgifte:
19-1-2009 20:52
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090120/7e489391/attachment.html
