[GRASS-user] GRASS Location from scratch: Solved
Paul Kelly
paul-grass at stjohnspoint.co.uk
Tue Jan 20 10:00:11 EST 2009
On Tue, 20 Jan 2009, "Peter Löwe" wrote:
> Hi,
> here is a working (bash-)scripting approach on how to conjure up a minimalistic xy-location out of thin air and to transmogrify the projection (f.e. EPSG:4326):
It doesn't really need to be so long though - in recent versions of GRASS
g.proj doesn't require a dummy location in order to run. This should do it
almost as well:
## LOCATION SETUP PREPARATION (FILESYSTEM)
#Set up a temporary grassrc-File:
echo "GISDBASE: $CURRENT_DIR
" > $TMPDIR/$THE_GRASSRC
# Export paths to GRASS binaries and libraries:
export GISBASE=/opt/grass
export PATH=$PATH:$GISBASE/bin:$GISBASE/scripts
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
# path to GRASS settings file:
export GISRC=$TMPDIR/$THE_GRASSRC
g.proj -c epsg=4326 location=$THE_LOCATION
#Delete temporary grassrc-File:
rm $TMPDIR/$THE_GRASSRC
The only difference is the default region will have an extent of 1 in all
directions. If you want to run a g.region command to set it at the end you
need to update the GISRC file with the name of the newly-created location
and PERMANENT mapset.
Paul
