[GRASS-user] problems with v.edit
Martin Landa landa.martin at gmail.com
Tue Jan 20 13:20:49 EST 2009
2009/1/20 chiaraercoli at tiscali.it <chiaraercoli at tiscali.it>:
> I have a problem with v-edit.
> I have to break a vector line
> into two parts near a point. I gave this command:
> v.edit map=ret_125
> layer=1 type=line tool=break thresh=$ris_edit coords=$x,$y snap=no
> where " $ris_edit "  depends on the resolution of the DEM raster map,
> "$x" and "$y" are the coordinates of the point.
are you sure that threshold value is enough to select vector feature
which you want to break?
v.edit map=ret_125 tool=select  thresh=$ris_edit coords=$x,$y
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
