[GRASS-user] Character encoding problem
Jana Krajcovicova
jkrajc at gmail.com
Wed Jan 21 03:22:17 EST 2009
That's correct Glynn, I've just tested that. The trick is as simple as to
use *Truetype* font and set charset to the encoding used in the input vector
map (Apparently, my GRASS was not built to use iconv() :-)
Anyway, GRASS is so nice, thanks to all of you :-)
Jana
> I can't comment on GDAL/OGR issues, but the display library will
> accept data in any encoding recognised by iconv[1] when using FreeType
> fonts. You just need to specify the encoding via the charset= option.
> [1] Provided that GRASS was built to use iconv(); this is
> autodetected. Otherwise, text is treated as ISO-8859-1.
> Glynn Clements <glynn at gclements.plus.com>
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20090121/f6f7a191/attachment.html
